Discussion Forum
problem creating a model using a Matlab function (Comsol 4)
Thread index  |  Previous thread  |  Next thread  |  Start a new discussion
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   6 Replies   Last post: February 1, 2012 4:33pm UTC
Chris Shor
Chris Shor
April 11, 2011 9:55am UTC
i want to create a Comsol model using a Matlab function like:
function myFunction()
model = ModelUtil.create('Model');
return
When i call the function Matlab returns this error:
??? Undefined variable "ModelUtil" or class "ModelUtil.create".
I guess somehow i have to tell Matlab to use Comsol 4 because it seems not able to find ModelUtil from within a function.
What am i doing wrong?
Thank you for any advice.
Reply  |  Reply with Quote  |  Send private message  |  Report Abuse
Chris Shor
Chris Shor
April 11, 2011 10:08am UTC in response to Chris Shor
Re: problem creating a model using a Matlab function (Comsol 4)
Just solved it - should have read the LiveLink-manual more carefully :) It is neccessary to import the Comsol classes first:
import com.comsol.model.*
import com.comsol.model.util.*
return
Arye Nudelman
Arye Nudelman
May 10, 2011 9:36pm UTC in response to Chris Shor
Hey i ask the same
thanks for your answer tomorrow i'll try it too
i want to make my model in comsol as a function in matlab and then i do sort of parametric
sweep on this model by using a for loop calling my model function and always with sweeping parameter
thanks a lot
and you think your advices here will work for me too?
Arye
Arye Nudelman
Arye Nudelman
May 11, 2011 5:35pm UTC in response to Arye Nudelman
Thanks it worked you are awesome
xuesheng chen
xuesheng chen
November 2, 2011 8:39am UTC in response to Arye Nudelman
Re: (Comsol 4) Undefined variable "ModelUtil" or class "ModelUtil.create"
We need install LiveLink before using matlab combined with comsol v4?
Ivar Kjelberg
Ivar Kjelberg
Moderator
November 2, 2011 9:30am UTC in response to xuesheng chen
Indeed you need a corresponding Matlab installed, then COMSOL With the Matlab livelink for V4 to get everything running together. Cehck with your local rep, or on the KB for install details
ilgin
ilgin
February 1, 2012 4:33pm UTC in response to Chris Shor
COMSOL model implementation via LiveLink (ModelUtil.create)
As an addition to the explanation from "Chris Shor"; it is also possible to run a LiveLink operation to start model implamentation without creating a MATLAB function file. That was especially helpful (and seems faster) in my case, since I have pre-processing of my data before starting model implementation.
To do so;
..._______________________________________________
%% PRE_PROCESSING
% constants
x = 1;
y = 2;
z = 3;
%% MODEL IMPLEMENTATION
mphstart % connect MATLAB to the COMSOL server (in default port)
import com.comsol.model.* % import the COMSOL classes
model = ModelUtil.create('Model'); % start model implementation
model.name('xxx');
model.param.set('x', [num2str(x) 'unit'], 'explanation'); % define global model parameters (constants)
model.param.set('y', [num2str(y) 'unit'], 'explanation');
model.param.set('z', [num2str(z) 'unit'], 'explanation');
return
Hopefully that will be helpful.
(LiveLink for MATLAB Users Guide - p.12-14)
COMSOL 4.2a
Ubuntu 11.04
MATLAB R2010a
Rules and guidelines
