<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
 <channel>
  <atom:link href="http://www.comsol.fr/community/forums/general/rss/thread/3787.rss" rel="self" type="application/rss+xml"/>
  <title>COMSOL Forums: Post-processing and integration of multiple solutions</title>
  <link>http://www.comsol.fr/community/forums/general/thread/3787/</link>
  <description>Most recent forum messages</description>
  <pubDate>Fri, 12 Mar 2010 20:05:43 +0000</pubDate>
  <image>
   <url>http://www.comsol.fr/shared/images/logos/comsol_logo.gif</url>
  </image>
  <item>
   <title>Re: Post-processing and integration of multiple solutions</title>
   <link>http://www.comsol.fr/community/forums/general/thread/3787/#p9868</link>
   <description>Hi&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
I believe you have the variable &amp;quot;'solnum',n&amp;quot; for your &amp;quot;post...&amp;quot; commands in matlab, but if I remember right these have different meaning depending on the application mode settings (eigenvalue, parametric, harmonic, transient ...) &lt;br /&gt;&#13;
&lt;br /&gt;&#13;
you have also the &amp;quot;at(12.5,u)&amp;quot; operator when you want to use a specific time tag value here for &amp;quot;u&amp;quot; in your comsol euqations, the &amp;quot;'solnum',n&amp;quot; varable has the &amp;quot;with(3,u^2)&amp;quot; operator ( here for &amp;quot;u^2&amp;quot; see the command.pdf doc)&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
If your solutions are from different runs you set up, I believe you must use matlab and store the different solution as fem1, fem2 ... and integrate in a loop within matlab&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
Good luck&lt;br /&gt;&#13;
Ivar</description>
   <guid isPermaLink="false">3787.1268424343.9868</guid>
  </item>
  <item>
   <title>Post-processing and integration of multiple solutions</title>
   <link>http://www.comsol.fr/community/forums/general/thread/3787/#p9859</link>
   <description>Hi,&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
I would like to integrate a Expression that involves variables from several different solutions obtain in a single application mode.&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
Second is doing a integrate an Expression what involves variables from two application modes but each has several solutions.&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
Is there a way to choose a specific solution (determined by parametric solver) from each mode and do an integration over a boundary?&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
&lt;br /&gt;&#13;
I can find out the value for each expression for a given boundary using postinterp. However, I get values so integrating smoothly becomes a bit of a problem.&lt;br /&gt;&#13;
I know there is the function postint, but I don't know if this can call a specific solution number in several application modes.</description>
   <pubDate>Fri, 12 Mar 2010 19:51:42 +0000</pubDate>
   <guid isPermaLink="false">3787.1268423502.9859</guid>
  </item>
 </channel>
</rss>
