Scattering boundary condition
COMSOL documentation tells that a scattering boundary condition makes the boundary transparent for scattered waves and when to use these boundary conditions.
But I haven't found anything about the mathematical background and how they are implemented. Can somebody tell me or give some references?
RB
2 Replies Last Post 21 oct. 2010, 05:46 UTC−4
Posted: 1 decade ago 21 oct. 2010, 05:30 UTC−4
Not sure if they are the same things, but in literature you can find a thing called absorbing boundary conditions (ABC). They are able to absorb only plane waves, and that is the feature of scattering boundaries in Comsol as well.
Posted: 1 decade ago 21 oct. 2010, 05:46 UTC−4
check carefully the doc there are many differneces between scattering boundary, infinite boundary and a perffectly matched boundary, they apply somewhat differently.
The best is to try out a set of simple cases
Hi check carefully the doc there are many differneces between scattering boundary, infinite boundary and a perffectly matched boundary, they apply somewhat differently. The best is to try out a set of simple cases -- Good luck Ivar
