fire modelling
Hi all,
I'm trying to model a fire in Comsol, to ultimately determine the heating of a steel ventilation duct which penetrates through a concrete wall. Up till now I have only tried to model the room and the fire.
I defined the fire as a temperature boundary at the bottom of the room with temperature: 20+345*log10(8*t[min]+1).
Does anybody have another (better) idea to model a fire in Comsol?
thanks.
2 Replies Last Post 26 déc. 2015, 10:31 UTC+1
Posted: 1 decade ago 7 déc. 2010, 16:49 UTC+1
I havent tried, but from the physical principles, I suppose you should mix conductive and radiative source exchange. Although the radiative issue is often tricky (and highly non-linear)
Hi I havent tried, but from the physical principles, I suppose you should mix conductive and radiative source exchange. Although the radiative issue is often tricky (and highly non-linear) -- Good luck Ivar
Posted: 10 years ago 26 déc. 2015, 10:31 UTC+1
Did you got your fire model working?
It works with convection only or convection and radiation? If applies radiation how you applied that mechanism?
Thank you so much in advance.
Happy new year
Valente Martins
Hello, Did you got your fire model working? It works with convection only or convection and radiation? If applies radiation how you applied that mechanism? Thank you so much in advance. Happy new year Valente Martins
