Need help with magnetic shield simulation with Comsol 3.5a
Posted 20 févr. 2011, 16:37 UTC−5 3 Replies
I try to simulate a permanent magnet which is put inside a steel pipe. First, I chose the magnetization of magnet is 100000 [A/m]defined boundary conditions for the walls of pipe become magnetic shielding with relative permeability of iron and thickness 1[mm]. The result is the magnetic flux still can go through the magnetic shields but not go along the thichness of iron shields. The distribution of magnetic flux density also was not uniform around the magnet. Can you help to solve that problem?
3 Replies Last Post 8 mai 2011, 05:01 UTC−4
