How to manage PC's memory when I compute the solution?
I have a problem in comsol when I was computing the solution, it has an eror "out of memory during assembly". What should I do to fix this problem?
1 Reply Last Post 5 avr. 2019, 15:13 UTC−4
Posted: 7 years ago 5 avr. 2019, 15:13 UTC−4
You can reduce the mesh resolution, use an iterative instead of a direct solver, use a lower order discretization to mention some of the typical options.
And you can buy more memory for your computer.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You can reduce the mesh resolution, use an iterative instead of a direct solver, use a lower order discretization to mention some of the typical options. And you can buy more memory for your computer.
