Material for SPRING?
Hello
Can any one suggest me which type of material to utilize from materials inorder to achieve the behaviour of spring made up of music wire ..
Krishna Chaitanya S.
1 Reply Last Post 15 déc. 2011, 14:47 UTC−5
Posted: 1 decade ago 15 déc. 2011, 14:47 UTC−5
Music wire is "just" a high strength steel, so E=200[GPa], nu=0.29, rho = 7750[kg/m^3] should do for modelling. The true difference is the maximum stress&strain such a wire can sand w.r.t. other steel sorts, but that is not in the FEM model, at most it is a mesure for a security factor w.r.t. the maximum stress obtained
The built-in "structural steel" is not far off neither
Hi Music wire is "just" a high strength steel, so E=200[GPa], nu=0.29, rho = 7750[kg/m^3] should do for modelling. The true difference is the maximum stress&strain such a wire can sand w.r.t. other steel sorts, but that is not in the FEM model, at most it is a mesure for a security factor w.r.t. the maximum stress obtained The built-in "structural steel" is not far off neither -- Good luck Ivar
