Boundary Distance Variable in Comsol 4
Hi folks,
I have been searching in the manual but I can't seem to find the boundary distance variable in Comsol 4.
I have used it in comsol 3.5a, and I need to use it again.
Can someone direct me to the name used in version 4? Or has it been replaced?
Rui
4 Replies Last Post 7 sept. 2012, 16:06 UTC−4
Posted: 1 decade ago 3 janv. 2012, 14:33 UTC−5
in my v4.2a help file I have a "Wall Distance Interface" or "wd" wariable, try a search
Hi in my v4.2a help file I have a "Wall Distance Interface" or "wd" wariable, try a search -- Good luck Ivar
Posted: 1 decade ago 4 janv. 2012, 06:50 UTC−5
Thks Ivar!
I have found it!
Gonna try to implement it!
Best Regards,
Rui
Thks Ivar! I have found it! Gonna try to implement it! Best Regards, Rui
Posted: 1 decade ago 7 sept. 2012, 13:30 UTC−4
Ivar,
I am trying to use "wd", but I cannot get the convergence. The model is two phase flow, and I coupled it with wall distance. I need the "wd" model to find the distance of the points of the domain to the wall, in order to monitor if the droplet touches the wall or not. Do you have any suggestion how to make it work? Am I allowed to couple wall distance with two phase flow or not?
Shawn
Ivar, I am trying to use "wd", but I cannot get the convergence. The model is two phase flow, and I coupled it with wall distance. I need the "wd" model to find the distance of the points of the domain to the wall, in order to monitor if the droplet touches the wall or not. Do you have any suggestion how to make it work? Am I allowed to couple wall distance with two phase flow or not? Thanks -- Shawn
Posted: 1 decade ago 7 sept. 2012, 16:06 UTC−4
sorry but that one I do not know ;)
and I'm far away from my COMSOL workstation so I cannot try and test it out, but there are others out here ;)
Hi sorry but that one I do not know ;) and I'm far away from my COMSOL workstation so I cannot try and test it out, but there are others out here ;) -- Good luck Ivar
