If condition in coupled PDEs
I am solving 9 coupled-Nonlinear PDEs. How can I add an "If condition" to dependent variables? (e.g constrained their value to change in a specific domain, 0 and 1)
(if x>1 then x=1 and if x<0 then x=0)
2 Replies Last Post 12 juin 2012, 10:43 UTC−4
Posted: 1 decade ago 7 juin 2012, 02:04 UTC−4
check the doc on the if() operator, or use Bolean expressions
Hi check the doc on the if() operator, or use Bolean expressions -- Good luck Ivar
Posted: 1 decade ago 12 juin 2012, 10:43 UTC−4
Thank you,
but I do not know where to put these IFs. I have 9 PDEs(g) and each of them has its own Gama and f. I add some if at the end of f part (force part) but it says Syntax error.
Should I add these IFs in Constraints part?
Thank you, but I do not know where to put these IFs. I have 9 PDEs(g) and each of them has its own Gama and f. I add some if at the end of f part (force part) but it says Syntax error. Should I add these IFs in Constraints part?
