How to export 'Plot' type data with MATLAB LiveLink?
Posted 30 juil. 2021, 08:53 UTC+2 LiveLink for MATLAB, API Version 5.5 0 Replies
Hi! I am using COMSOL Livelink for MATLAB and trying to export a 'Plot' type data as .txt file with MATLAB code. I have read the manual for MATLAB livelink and found API only for data of 'Data' type or 'Animation' type. I have tried the following command and it works,
data = model.result.export.create('data', 'Plot');
However, I can't specify which plot group this export object connects with. Then I tried the following command (Inspired by API doc of Livelink for Java),
data = model.result.export.create('load_deflection_curve', 'Load-Disp Plot', 'Plot');
Sadly it doesn't work in MATLAB. The error info is as follows,
Java exception occurred: Exception:
com.comsol.util.exceptions.FlException: Unknown feature
Unknown feature.
Tag: Load-Disp Plot
Does anyone know how I can proceed with the first command and specify the plot group? Thank you!
Hello John Lionel
