Visualization problems
The java heap space problem is solved, but now the simulation reaches 100% of the linear solver and nothing happens, Comsol uses a core of four available cores, I give same time that Comsol takes to reach 100% complete linear solver and nothing happens, still in the same state.
In other attempt for to solve this problem, I remove the check in "Generate default plot" box, and them Comsol finish the simulation without problems or errors, but when I tried to plot the "particle trayectory", happens that, when Comsol attempts to load time data of "Particle" do not finish this task, at least for one day of elapse time.
The features of simulation are:
>>1 600 000 elements (magnetic field solution)
>>The elements for particle tracing should be more low, because is solved for part of entire geometry.
>>The time of simulation is for one second and steps of 1e-6 seconds (1 million of steps)
>>The size of Solution file is 8 Gb aprox. in .mph file, and the .mph file size is 4 GB aprox. (ccompressed file).
Thanks for your help.....
0 Replies Last Post 10 sept. 2012, 19:49 UTC−4
Hello Esteban Zamora
