Livelink for MATLAB
I am learning how to use LiveLink for MATLAB. The problem is when I try to plot an external matlab functions in a model, an error message appear with Fatal error.
Please note that the MATLAB directory is properly defined, and I already went through creating an application through MATLAB interface (busbar documentation) and it worked fine. the problem appears only when I want to call functions from MATLAB to COMSOL interface. Also, I set the allow MATLAB external functions to 'YES' and checked the box for allow external processes (in preferences security).
Regards, Mohammad Hdaib
1 Reply Last Post 24 mai 2023, 05:24 UTC−4
Posted: 11 months ago 24 mai 2023, 05:24 UTC−4
This could be an installation problem. There is an example in the Model Library for LiveLink for Matlab called Vaccum Flask. Does that work for you?
If the example doesn't work for you I suggest you contact support. Please submit the exact error message you see.
Lars Gregersen
Comsol Denmark
This could be an installation problem. There is an example in the Model Library for LiveLink for Matlab called Vaccum Flask. Does that work for you? If the example doesn't work for you I suggest you contact support. Please submit the exact error message you see.
