Projection coupling in Comsol 4
Yet with another how-to-use on Comsol 4.
Similiar to Comsol 3 I tried to use a projection coupling variable to project a "u" from boundary A to "u" on boundary B.
Model: www.gliffy.com/pubdoc/2140940/L.png
Here I want to project "u" from the inner circle to the outer one, so I can use "u" on the outer boundary. In Comsol3 all I needed to do was to add 3 red vertices as source and 3 blue ones as destination. But, in Comsol 4 it doesn't work that way. It always says illegal vertices. Help file is not enough at all to solve it on my own.
2 Replies Last Post 11 août 2011, 12:56 UTC−4
Posted: 1 decade ago 9 juin 2010, 16:35 UTC−4
Oops! It should have been extrusion variable, and yes, that was the source of confusion :) problem solved.
Posted: 1 decade ago 11 août 2011, 12:56 UTC−4
I'm having the same issue with the error "illegal vertex selection". Would you be able to explain what you did in a little more detail to get around this issue?
Leanne
I'm having the same issue with the error "illegal vertex selection". Would you be able to explain what you did in a little more detail to get around this issue? Thanks, Leanne
