Induced Voltage on straight conductor simulation vs. calculation
Dear community,
I am currently in the early stages of learning COMSOL Multiphysics and have been working on a simple problem to calculate the induced voltage in a straight conductor.
Problem setup:
A copper conductor with dimensions:
  • Side length: 0.01 m
  • Length: 0.1 m
Placed in an air domain:
  • Air domain of 1m × 1m × 1m
  • Exposed to a time-varying magnetic field with dB/dt = 1 mT/s
I am using Magnetic fields physics (mf) and Time dependent simulation.
According to Faraday’s Law, the expected induced voltage should be:
However, when I perform a line integration of mf.normE over one edge of the conductor, I obtain a result of 1.25 µV, which is significantly lower than expected.
I would appreciate any insights into what might be causing this discrepancy. I include the .mph file.
Thanks in advance for your help!
1 Reply Last Post 21 févr. 2025, 12:12 UTC+1
Sven Friedel COMSOL Employee
Posted: 5 months ago 21 févr. 2025, 12:12 UTC+1
Updated: 5 months ago 21 févr. 2025, 12:12 UTC+1
Hi ,
B has the unit [Vs/m^2] . The induced voltage is obtained by integrating the flux change over an area, not along a line.
So your integral gives you 100 uV/m, not 100 uV.
Best regards Sven
Hi , B has the unit [Vs/m^2] . The induced voltage is obtained by integrating the flux change over an area, not along a line. So your integral gives you 100 uV/m, not 100 uV. Best regards Sven
Reply
