solver scripting
A question about solver scripting:
I have a linear elastic problem in 3D, with changing load (fracture opening under internal pressure). I set up the problem from Matlab and I would like to solve the problem once and recover the inverse system matrix.
I can then quickly solve the problem for another load. It is unclear from the manual which functions I could use to accomplish this.
The functions I need would return inverse matrix and (for the changing load) the load vector.
Do you perhaps an example of such a solution script?
0 Replies Last Post 11 oct. 2010, 18:38 UTC+2
Hello Hans de Pater
