export wave simulation result in text file
Posted 8 mars 2016, 00:06 UTC−5 Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers, Structural Mechanics 1 Reply
I have done a 2D time-dependent simulation of elastic wave propagation in a linear elastic medium. I have done it in 4.2a running on Linux. My desired output is displacement component along y at all nodes at each time step.
I have been able to visualize the result in Comsol using animation. But, I couldn't export the raw displacement data to a text file. I could, however, export the displacement field at any specific time step. But, for my analysis, I need all the frames and it is nearly impossible to go to each frame and do this.
I don't want to save the data using GIF animation, image format or video format, I just want the raw displacement in a text file for all frames at each node. It would be really helpful if you could suggest me a way to do this.
Thanks in advance.
-Rifat
Thanks in advance.
-Rifat
1 Reply Last Post 8 mars 2016, 02:21 UTC−5
