                                10 years ago
                                14 mars 2016, 16:45 UTC−4
                                                    You can write a method in Application builder and run it.
In method you can  have  a for loop.
for (i=1, i<=10, i++){
model.study("std1").run();    // Study A
 model.study("std2").run();// Study B
for (i=1, i
                                Walter Frei
        COMSOL Employee
                                10 years ago
                                14 mars 2016, 17:36 UTC−4
                                                    Alternatively, you can use a segregated approach. For a conceptual introduction, see:
www.comsol.com/blogs/improving-convergence-multiphysics-problems/
Or, if you want to be a bit more explicit, add a series of study steps wherein you solve the different physics sequentially.
http://www.comsol.com/blogs/improving-convergence-multiphysics-problems/
                                10 years ago
                                15 mars 2016, 05:17 UTC−4
                                                    Hi all,
Thanks a lot for your help !
Sorry but my problem is still not be solved as I expect.
For example, I use ODE in Time-Dependent Study:
      Name: x,  f(u,ut,utt,t)= x*t[1/s]-2*y-1
      Name: y,  f(u,ut,utt,t)= y-3*x
I want to let Comsol solve x-->y-->x-->y-->x....
At t=0, x=0 --> y=0
At t=1[s], --> x=1 --> y=3
At t=2[s], --> x=3.5  --> y= 10.5
But when I use Segerated Approach in Comsol, the result is different.
Can you help me how to get the result I want ?
N. N
                            Hi all,
At t=0, x=0 --> y=0
N. N
                                10 years ago
                                15 mars 2016, 11:48 UTC−4
                                                    Hi Walter,
Thank you very much.
N. N
                            Hi Walter,
N. N
                                10 years ago
                                15 mars 2016, 13:57 UTC−4
                                                    Hi Sohan,
Sorry for repeating my question but my problem is still not be solved as I expect.
At t=0, x=0 --> y=0                            (loop number 1)
At t=1[s], --> x=1 --> y=3                  (loop number 2)
At t=2[s], --> x=3.5 --> y= 10.5        (loop number 3)
N. N
                            Hi Sohan,
N. N
