modeling sessile droplet evaporation
Posted 27 janv. 2011, 07:18 UTC−5 5 Replies
Dear Firends,
does any one has experience with modeling phase change from liquid to gas ? is there exists any tutorial ?
I intended to model evaporation of single droplet pinned of relatively hot serface .
I used general heat trasfer , incompresible navier stock and 2phase flow laminar phase field .
how could I check the conservation of mass and energy ?
I tried to run above problem with Moving Mesh ,ALE but I could not ,any suggestion ?
there is one toturial regarding 'Boiling water' I can not implement q (heat flux 1 & 2 ) in expresion ! I got error in expression and I can not run it , I assume t must be defined in other way but I have no idea how it should be define !
thank you in advance for your time and consideration
5 Replies Last Post 3 déc. 2012, 19:58 UTC−5
