POISSON RATIO
Hi everybody,
Does someone know how to solve a mechanical linear problem (isotropic) with a material that presents a Poisson ratio of exactly 0.5?
is it possible to solve it or should I set this numeber as strigtly smaller?
Giulio
2 Replies Last Post 16 févr. 2011, 16:57 UTC+1
Posted: 1 decade ago 16 févr. 2011, 12:10 UTC+1
no exactly 0.5 is not possible but 0.499 yes,
In that case turn also on the "nearly incompressible material" selection as this will add the pressure pw as dependent variable and help the solver via the pressure analysis
Hi no exactly 0.5 is not possible but 0.499 yes, In that case turn also on the "nearly incompressible material" selection as this will add the pressure pw as dependent variable and help the solver via the pressure analysis -- Good luck Ivar
Posted: 1 decade ago 16 févr. 2011, 16:57 UTC+1
hi Giulio,
since nu = 0.5*(3K-2G)/(3K+G), it can never be exactly 0.5, since it would mean G=0. For energy considerations, both K and G should be > 0.
As Ivar said, in the case K>>G, you will approach nu = 0.499999
On the other hand, I don't think Comsol performs any checks on your material properties, so in theory, you could input negative densities, velocities higher than the speed of light, or Poisson ratio equal to 1.5. (the solver might give you some answer, but of course it will not be correct)
john
hi Giulio, since nu = 0.5*(3K-2G)/(3K+G), it can never be exactly 0.5, since it would mean G=0. For energy considerations, both K and G should be > 0. As Ivar said, in the case K>>G, you will approach nu = 0.499999 On the other hand, I don't think Comsol performs any checks on your material properties, so in theory, you could input negative densities, velocities higher than the speed of light, or Poisson ratio equal to 1.5. (the solver might give you some answer, but of course it will not be correct) john
