Singular Matrix and revolved mesh?
Posted 16 nov. 2009, 11:27 UTC−5 Geometry, Mesh, Studies & Solvers Version 4.2a 17 Replies
After revolving my rather simple geometry and applying my subdomain/boundary conditions, I am clicking the Solve button and receiving a Singular Matrix error. This is an acoustics / structural mechanics coupled problem.
Since I am always getting the same 'Singular revolutions not supported for triangular elements' (4123) error message, I am using Quad elements while revolving my mesh. I am ticking on the Symmetric check box and applying my subdomain and boundary settings afterwards. After clicking on the solve button, I can follow in the text region below, Comsol is complaining about avoiding some inverted elements. Unlike my other cases (other 3D or axi-symmetric models), the repeated lines have different number of inverted elements. And, I am receiving a Singular matrix (7111) error.
I have checked the 'Singular Matrix' section of the knowledge database and I have checked the explanation of the error number 7111. I am sure that my element quality is over than 0.005 as indicated by Comsol and my problem doesn't fit any of the explanations in the knowledge base.
Has anybody struggled with this problem before?
/Onur
I havn't got into the same problems, yet, but I do see that on the rotation axis you can easily get "singular" values and problems because of mesh geometry shapes. everything converges on this axis so your prisms are not very "prismatic". There are a few comments about this somewhere in the documentation, I have forgotten exactly where now.
On trick/way around is to leave a small "hole" in the structure on the axis, but this is not always compatible with the models.
It is correct that tri's cannot be revolved to tets, but you can always get back to tet's by appplying the "prism to tet" conversion in the meshing options, once the part is revolved
In axisymmetric mode the singularity effets are minimised because COMSOL uses the trick to multiply several dimensions by "r" to avoid the 1/r for r=0 asymptote.
Hope this can help you on the way, good luck
Can you please let me know how u could solve your problem?
I have a same error with using free quad mesh.
Please help me.
Best Wishes,
Ali
I have a same problem and i can't solve it. Please help me.
Best Wishes,
Ali
try avoid a quad mesh on the axis of rotation, it could be an issue (but it might be accepted by COMSOL by now in the newer versions)
Thanks your kind attention.
But I have a very simple geometry that u can see in the attached file. Meanwhile I use a new version on COMSOL.
Would you please give me another solution?
Best Wishes,
Ali
start using COMSOLs default mesh probably it will work easier
Thanks your quick reply.
I know about default mesh, but i should use quad mesh for my geometry.
I have to use quad mesh or i should present reason why it is not possible.
Could you please help me?
Best Wishes,
Ali
He has probably a good reason, but I'm not sure its possible through the full system with COMSOL, play a little with the swwep mesh too and try, probbaly he wants you t find the correct way out
Thanks your help.
I have tested with swept meshing and i can solve for regular structures. But when my structure is irregular it is not possible to use swept mesh. I don't know what I should do now.
Best Wishes,
Ali
In fact neither do I for a swept mesh in your geoemtry case.
But what I still would do, is to solve it with thets, and validate that the results are still reasonable, then read carefully the doc about uqad and swept mesh, make a few examples and explain why you could NOT use a quad mesh. And perhaps give a short introduction to all the mesh types in COMSOL: tri, quad, thet, brick ...
In this way you will be more familiar with the mesh types and when they apply, nothing better than a few examples for any learning process, I still do it regularly when entering a new field, or revisiting one where I have not been for some time, even 30+ years after my studies ;)
Thanks your kind guides.
I have tried to find scientific reason for why free quad cannot solve my simulation even for very simple geometries but i don't find the answer yet. :(
What is your idea about the question?
Best Wshes,
for me its the way COMSOL generate the mesh, it is not possible (from my udnerstanding) in v4.2 to use swept or structured mesh on such uneven geometries.It's only a mesh generation issue not a FEM issue.
Perhaps in the new v4.3 where the mesh generation has been improved, it will be posible ?
I don't have a new version of COMSOL and I can't check it. :(
But if you are sure about it maybe i can ask my university to buy it.
and about free quad you think reason is COMSOL's mesh ability?
Best Wishes,
Ali
if your university is wise (and rich enough) it has a maintennce running then you will receive the new version soon.
To test meshes, make a simple rectangle/cube and try out the different meshes, then add a circle/sphere in the middle and try again, test the sweep mesh too in 3D and 2D
Thanks your helps.
I checked it but still solving free quad meshing is singular.
However i thanks your good comments.
Best Wishes,
Ali
Sorry for my bothering.
I have a another question that if i can answer it maybe i can solve my problem. You saw my geometry that two cube have a intersect with each other. I want to use surface instead of cubes because physically it is possible. I tried to use rectangular shapes but in the 3D it is not possible. Would you please let me know what i can do?
Best Wishes,
Ali
I do not believe so (but I might be wrong :)
you need the 3D domains as you have no true symmetry in your geometrical model
