Frequency-Domain Modal Analysis of Piezoelectric Device
Hi, I got a problem with the Frequency-Domain Modal Analysis. It works fine for the attached model until I add an electrical circuite connected to my device. I get the error "Feature: Modal Solver 1 (sol1/mo1) - No eigenpair solution detected." and have no clue how to solve that.
Any suggestions?
Best regards, Matthias
1 Reply Last Post 29 mai 2018, 11:59 UTC+2
Posted: 7 years ago 29 mai 2018, 11:59 UTC+2
Meanwhile I found out that by changing some properties of the Modal Solver, the error disappears, which leads me to another question: Is it possible to combine the Frequency-Domain Modal Analysis with an Electric Circuite Interface so that I can see Voltage and Current through a Resistor for a given harmonic perturbation of a vibrating beam, like in the model file above?
Br, Matthias
Meanwhile I found out that by changing some properties of the Modal Solver, the error disappears, which leads me to another question: Is it possible to combine the Frequency-Domain Modal Analysis with an Electric Circuite Interface so that I can see Voltage and Current through a Resistor for a given harmonic perturbation of a vibrating beam, like in the model file above? Br, Matthias
