Using a certain temperature of the geometry (for example a point on a surface)
I want to make a model in the heat transfer module in order to cool down a small cylinder with a water jet. Therefor I need to define the heat transfer coefficient in function of the temperature of the surface. what is the common way to introduce a certain temperature of a point in your geometry (cordinates) to use this temperature in your setting of the HTC value?
2 Replies Last Post 10 mai 2011, 15:02 UTC+2
Posted: 1 decade ago 10 mai 2011, 13:53 UTC+2
if you need to get (as a global value/variable i.e. a temperature T) the value of a dependent variable at a given point (by analogy edge, boundary or domain) you define a My_T = intop1(T) where intop is an integration coupling operator define ON THE POINT (or an aveop1(), average operator defined on the edge, boundary or domain respectively)
This is the COMSOL way to get the temperature at a given position from the dependent variable field T,
as MyT = T(x0,y0,z0) for the Point (x0,y0,z0)
Integration over points is the sum over the different points, when only one its THE point
Hi if you need to get (as a global value/variable i.e. a temperature T) the value of a dependent variable at a given point (by analogy edge, boundary or domain) you define a My_T = intop1(T) where intop is an integration coupling operator define ON THE POINT (or an aveop1(), average operator defined on the edge, boundary or domain respectively) This is the COMSOL way to get the temperature at a given position from the dependent variable field T, as MyT = T(x0,y0,z0) for the Point (x0,y0,z0) Integration over points is the sum over the different points, when only one its THE point -- Good luck Ivar
Posted: 1 decade ago 10 mai 2011, 15:02 UTC+2
thank you Ivar, but can you say where I need to define these exactly?
Thanks a lot!
Hi, thank you Ivar, but can you say where I need to define these exactly? Thanks a lot!
