Square wave temperature boundary
Dear sir,
I would like to have a time varying inlet temperature for fluid, flowing in an annular channel. The fluid temperature follows a square wave pattern with maximum temperature at 663.15 K and minimum at 623.15 K. I have created an analytic function for the same but the time dependent solution shows an error on execution (Failed to find consisitent initial values. Last time step is not converged.)
I have attached my comsol file for reference.
Thanking you Harshal Srivastava
1 Reply Last Post 24 juil. 2018, 16:10 UTC+2
Posted: 7 years ago 24 juil. 2018, 16:10 UTC+2
Hi Harshal,
Is this what you are looking for? https://www.comsol.com/blogs/modeling-a-periodic-heat-load/
Regards, Nichal
Hi Harshal, Is this what you are looking for? https://www.comsol.com/blogs/modeling-a-periodic-heat-load/ Regards, Nichal
