how to export post processed data of one model as input to another modal
hi everyone
I have two comsol modals and one of them generates a voltage and temperature on a surface and the other needs these voltages and temperatures as input for simulations.I cannot put both in the same modal as that would become very complex.
Now my question is how to I export the voltage and temperature distribution in a surface from one modal and to another modal which has a surface of same shape.
I am using comsol 3.5a with mems module
thanking you
Vikrant Sista
3 Replies Last Post 18 juil. 2011, 11:52 UTC+2
Posted: 1 decade ago 16 juil. 2011, 19:05 UTC+2
Ivar I have seen in some of you similar old posts that you refer to a certain "history file".Can you tell us where we can find it?
Posted: 1 decade ago 18 juil. 2011, 11:32 UTC+2
Hi, same question here but for 4.1 version please.
I run a 2D analysis to obtain temperature along a boundary, and another analysis which needs this temperature profile as an input.
I can export the data from the first model via a txt file but i don't know what to do afterwards....
Thank you for your help!!!
Hi, same question here but for 4.1 version please. I run a 2D analysis to obtain temperature along a boundary, and another analysis which needs this temperature profile as an input. I can export the data from the first model via a txt file but i don't know what to do afterwards.... Thank you for your help!!!
Posted: 1 decade ago 18 juil. 2011, 11:52 UTC+2
Actually I managed to get it into a function using the interpolation, and I have now a function of the temperature for values of X. But I can't affect this function to a boundary condition (Temperature in my case) becaus e it is not a single value -> I have these error messages :" Unexpected unit of input", or "Unknown variable"....
Does anybody know haw I can handle it?
Ok found it, never mind ^^...
Actually I managed to get it into a function using the interpolation, and I have now a function of the temperature for values of X. But I can't affect this function to a boundary condition (Temperature in my case) becaus e it is not a single value -> I have these error messages :" Unexpected unit of input", or "Unknown variable".... Does anybody know haw I can handle it? Thanks Ok found it, never mind ^^...
