Defining a domain within an imported SolidWorks part
I have a SolidWorks part which has holes for tubing in it. When I complete the laminar flow physics, the flow is going through the whole part instead of the holes where the tubing is. How do I define the tubing hole as its own domain, so I am able to have the fluid only flow in the one hole and out the other?
Thank you,
Nina
3 Replies Last Post 25 oct. 2018, 20:08 UTC+2
Posted: 7 years ago 25 oct. 2018, 17:59 UTC+2
Hello Nina,
The functionality you are looking of is called "Cap Faces". You can read more about it in this older thread.
Jeff Hiller
Hello Nina, The functionality you are looking of is called "Cap Faces". You can read more about it in [this older thread](https://www.comsol.com/forum/thread/134711/filling-an-empty-space-with-fluid-heat-transfer-in-solids?last=2017-01-27T12:17:21Z). Best, Jeff
Posted: 7 years ago 25 oct. 2018, 19:59 UTC+2
Hi Jeff,
Thank you for this information, but the defeaturing and repair option I'm not able click. I am in the 3D mode as well.
Is there another way to have the defeaturing and repair option to become available?
Thank you,
Nina
Hi Jeff, Thank you for this information, but the defeaturing and repair option I'm not able click. I am in the 3D mode as well. Is there another way to have the defeaturing and repair option to become available? Thank you, Nina
Posted: 7 years ago 25 oct. 2018, 20:08 UTC+2
Hi Nina,
As this second question appears to be only tangentially related to the first, I would suggest you start a separate thread for it, and also provide more context (If you could post the .mph file that's giving you trouble in particular, you are more likely to get useful suggestions from other Discussion Forum users).
Jeff Hiller
Hi Nina, As this second question appears to be only tangentially related to the first, I would suggest you start a separate thread for it, and also provide more context (If you could post the .mph file that's giving you trouble in particular, you are more likely to get useful suggestions from other Discussion Forum users). Best, Jeff
