Set export window using java
I'm using the java API to build my 2Dmodel and I made a plot which has a high height-to-width ratio. When I try to create an animation using the java export function, I get a lot of white-space above and below the model since it fits the plot in the width direction. In the GUI this would be solved by resizing the plot window and simply exporting again. I can't find a java command to do this automatically.
I would like to have some sort of java command which allows me to set an export window.
(P.S. I am using Comsol for Linux so my only options are .gif and flash (.swf) and I'm not a big fan of .swf since I can't get it to work in my presentation.)
Any help would be very much appreciated,
With kind regards
0 Replies Last Post 14 févr. 2019, 09:36 UTC+1
Hello Frits Rooyackers
