Adhesion between two layers
I am interested in studying the adhesion between two layers. There is also a Link for it: https://www.comsol.com/blogs/how-to-model-adhesion-and-decohesion-in-comsol-multiphysics/
But I cannot find the subnode 'Adhesion' to the 'Contact' node in the model tree in the Model Builder. Can anyone help?
1 Reply Last Post 24 févr. 2019, 23:24 UTC+1
Posted: 7 years ago 24 févr. 2019, 23:24 UTC+1
You have to select penalty method for the contact pressure method and then you will see the adhesion option. Note the default I usually see is Augmented Lagrangian.
Suresh
Hi, You have to select penalty method for the contact pressure method and then you will see the adhesion option. Note the default I usually see is Augmented Lagrangian. Suresh
