size of Tetrahedral elements
Hii everyone,
i am using COMSOL 3.5a, i created 3D model and meshed it with method longest. Now i want to know the size of Tetrahedral elements, can any one tell me how can i do that.
Adnan
2 Replies Last Post 20 oct. 2011, 09:18 UTC−4
Posted: 1 decade ago 20 oct. 2011, 04:51 UTC−4
check the doc (index the pdf with an indexer, its the easiest) if I rem,ember right it's the variable "h" that describes this, not sure any longer if you can get the max value like that in v3.5 without matlab ?
Hi check the doc (index the pdf with an indexer, its the easiest) if I rem,ember right it's the variable "h" that describes this, not sure any longer if you can get the max value like that in v3.5 without matlab ? -- Good luck Ivar
Posted: 1 decade ago 20 oct. 2011, 09:18 UTC−4
How can i do in Matlab? if i have all the Node and element information..
