posteval vs mpheval AND postdataplot vs ???
Posted 6 déc. 2011, 05:57 UTC−5 Interfacing Version 3.5a, Version 4.2a 0 Replies
Recently I started using the newer version of comsol (v4.2a). Before, I used version 3.5a.
In my old models (with v3.5a), I very often used the posteval command in matlab to analyse the simulation data of my comsol model. This posteval command created a matlab-structure in which one of the components contains the data information (e.g. displacement values) I needed. After performing some transformations on the data (e.g. Fourier transforms or inverse Fourier transforms) I was able to plot the transformed data using the postdataplot-command, which uses the matlab-structure created with the posteval command.
Now, in the newer version of comsol, I would like to do the same analysis. Again, the data from comsol can be analysed in matlab by using the mpheval command (instead of the posteval command). However, after transformation of the data, I cannot plot it anymore. It seems that the function postdataplot from the older versions of comsol has totally disappeared in the newer versions. Is there still a way to be able to plot the matlab structure that results from the mpheval command?
Hoping someone of you has an answer to this.
Kind regards,
Steven Delrue
Hello Steven Delrue
