help for time dependent heat source
hello,
I am a newbie in comsol things, however, have already ansys experience.
I am looking for a possibility of a physical time-dependent heat source (0-10s [0 W], 10-20s [1000 W], 20-1000s [0 W]) raise. I've seen in comsol there is a rectangular function, I could use this function. and how exactly?
is there a tutorial for such a case?
Thank you. jojo
4 Replies Last Post 13 avr. 2012, 14:01 UTC+2
Posted: 1 decade ago 11 avr. 2012, 15:32 UTC+2
Maybe you can use a step function 2 times. The first up at 10 s and the second a step down at 20 s.
Than use this function in the boundary conditions.
Maybe you can use a step function 2 times. The first up at 10 s and the second a step down at 20 s. Than use this function in the boundary conditions.
Posted: 1 decade ago 12 avr. 2012, 07:56 UTC+2
you may try interpolation function, just right click on global definitions in model builder window then click on interpolation function, there you can specify any quantity varying with time.
Posted: 1 decade ago 13 avr. 2012, 11:32 UTC+2
hello,
I myself have found a solution, I have a rectangular function and a parameter defined with the heat source and a time-dependent variable with the rectangular function, then I have to load the model heat source definition of the multiplikation of variable and parameter.
But I have a new question:
When I model at a certain point or surface temperature is reached a previously known, is an additional load to be applied, so to speak a kind of chain reaction.
sure someone has a tip?
Thank you. jojo
hello, I myself have found a solution, I have a rectangular function and a parameter defined with the heat source and a time-dependent variable with the rectangular function, then I have to load the model heat source definition of the multiplikation of variable and parameter. But I have a new question: When I model at a certain point or surface temperature is reached a previously known, is an additional load to be applied, so to speak a kind of chain reaction. sure someone has a tip? Thank you. jojo
Posted: 1 decade ago 13 avr. 2012, 14:01 UTC+2
Maybe you can use a kind of control function.
An example of a PID control you can find here: www.comsol.com/showroom/gallery/866/
I'm not sure if this is what you are looking for.
Maybe you can use a kind of control function. An example of a PID control you can find here: http://www.comsol.com/showroom/gallery/866/ I'm not sure if this is what you are looking for.
