Error with Initial Value / BC
Posted 5 févr. 2021, 02:19 UTC−5 Electromagnetics, Electrochemistry Version 5.4 0 Replies
Basically I have a model with laminar flow, transport of diluted species (tds), and current distribution (cd). If I run laminar flow and tds together there is no issue.
If I use laminar flow, tds, and cd together the it works for an electrolyte potential of 0.2 Volts or less. However if I make the potential anything higher (0.3V for example), I get the error: "failed to find consistent initial values: last time step is not converged". What can I do to fix this? I have verified all my physics and BCs are correctly defined. Additionally, the mesh should not be causing the issue.
Hello Scott Burlison
