Convergence error
Posted 2 avr. 2021, 20:26 UTC+2 Electromagnetics, Materials, Mesh Version 5.5 1 Reply
I am new to COMSOL and trying to figure out why I am getting a convergence error when trying to run a simple joule heating and structural deformation test. The structure contains 2 copper blocks, 200 um wide, attached by a 1 um thick solder layer. The error I'm getting is given below:
Failed to find a solution. In Solid Mechanics: The relative error (0.011) is greater than the relative tolerance. There was a warning message from the linear solver. Iterative refinement triggered. Returned solution is not converged. Not all parameter steps returned.
Some possible solutions I tried are given below: 1) Reduce the size of the mesh 2) Add heat flux to allow the heat to exit and reach a stationary result
I am conducting a stationary study as that is what is required for my research. I am attaching the file to this post as well. I am not sure if missing material properties is causing this issue as well. Any suggestions are highly appreciated.
