Modeling mass flow through 2 channels
Posted 7 juil. 2021, 12:18 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics Version 5.6 0 Replies
I am trying to model mass flow through two different channels, 3 channels, and 4 channels. Theoretically the flow should divide based off of the amount of channels in the simulation. If the flow is 0.02 kg/s, it should divide to be about 0.01 kg per channel, but when I do a cutline and measure the flow away from the center, it is showing a constant 0.02 kg/s in each channel. Has anyone ever encountered this problem/ know how to fix it? I added pictures to the end since the file was too large to add by itself.
Hello Liam O'Brien
