Failed to copy mesh: Periodic Nanoparticle on Substrate structure
Posted 11 août 2021, 14:09 UTC−4 RF & Microwave Engineering, Semiconductor Devices, Wave Optics 1 Reply
Hello All,
I am trying to construct a periodic plasmonic array on a substrate. The image of the structure is attached. There are silver trinagular particles placed on top of the Quartz substrate. These plasmonic nanoparticles are placed within thin silica spacer layer. I am trying to do meshing by following the "scatterer on a substrate" model. However I am getting error when building the meshing. The error is generated by the copy face 1 (error image attached). This error doesn't occur if I remove the spacer layer. The nanoparticle height is 45 nm and spacer layer varies from 45 nm to 100 nm (spacer height is variable). Any suggestions? Best Regards,
Hamza
