Mesh error
Eduardo Nicolas Schulz
Hi. I'm trying to model this micro turbine section that consist of the outer steel case and the internal air volume. When getting to the mesh section I got this error "A problem occurred when building mesh feature 'Free Tetrahedral 1'" Also, when setting the boundary conditions I would like to set the mass flow for the air and flue gas inlets but I cannot fins the option. I can only set it as temperature and upsetream pressure. I will appreciate any help you can provide with this. Thank you. P.S: I tried to upload the comsol file but it exceeds the size limit even when compressed.
0 Replies Last Post 8 juin 2022, 12:51 UTC+2
Hello Eduardo Nicolas Schulz
