Cacluate power exchanged between solid/fluid and solid/solid
Posted 4 nov. 2012, 22:51 UTC+1 Acoustics & Vibrations, Structural Mechanics Version 4.3 1 Reply
Dear all,
I've solved a coupled linear elasto-acoustic model using COMSOL's Acoustic-Solid Interaction module. During the post-processing I would like to calculate energy balances to better analyze the implemented system. I have 2 questions.
Firstly, so far I've managed to calculate the power exchanged between a solid and a fluid domain using the surface integration function. However, I noticed that using the local velocity components (spatial) "acsl.vx, acsl.vy, acsl.vz" of the fluid domain provides a correct result whereas using the the velocity components of the solid domain (Material) "acsl.u_tX, acsl.u_tY, acsl.u_tZ" results in a deviation. Usually these two velocities should provide the same results due to the continuity of stress vectors and displacements. How come the results are different?
Secondly, I have problems implementing the power exchanged between two solid domains. I would like to implement the "...surface_integral((sigma.n) * conj(...))". I have difficulties to chose the correct tensor of constraints from the list.
Thank you very much in advance.
Kind regards,
Martin
Kind regards,
Martin
1 Reply Last Post 13 nov. 2012, 15:08 UTC+1
