Simulation of a pull-out test giving error.
I am trying to verify the experimental results of a pull-out test using COMSOL 4.2 But I am getting errors.
The geometry is as follows:
A cavity is made in a cylinder made of concrete. Now a steel bolt is grouted to the inner walls of the cavity. A pull of 10kN is applied on the steel rod. I need to get the resultant stress distribution and the displacements in the entire structure. I am not able to deal with the 2 interfaces(the steel-grout and the grout-concrete interfaces). Please suggest as to how to go about this problem. I am getting solutions in which only the strain on the rod is calculated and everything else ignored, even though I am using "Form Assembly".
Any help would be appreciated. Thank you.
1 Reply Last Post 12 nov. 2012, 01:20 UTC+1
Posted: 1 decade ago 12 nov. 2012, 01:20 UTC+1
I suggest as a first step that you start with forming a union instead of assembly and making sure the model works and you get the results you expect for this setting. In that case you do not need to define contact or any form of interaction between the materials. Then work your way backward and convert one of the interfaces at a time to Assembly.
Nagi Elabbasi
Veryst Engineering
I suggest as a first step that you start with forming a union instead of assembly and making sure the model works and you get the results you expect for this setting. In that case you do not need to define contact or any form of interaction between the materials. Then work your way backward and convert one of the interfaces at a time to Assembly. Nagi Elabbasi Veryst Engineering
