Help : Repeated error test failures. May have reached a singularity.
Posted 25 nov. 2023, 14:46 UTC−5 Fluid & Heat, Computational Fluid Dynamics (CFD), Studies & Solvers Version 5.6 0 Replies
I have used Comsol version 5.6 for a coupled analysis of Heat Transfer module and turbulent flow of HTF for simulate a 2D model of a tubular absorber with a time dependent study. I have tis Error since i change the relative tolerance from 0.1 to 0.001 : Repeated error test failures. May have reached a singularity. Temps: 229.24111918757333. Last time step is not converged
Can anyone spot the glitch here and help me out, kindly?
Thank you in advance
Hello Soumia Chatioui
