Filling of a microfluidic well using 2 phase flow, level-set method
Posted 29 août 2024, 00:26 UTC+2 Computational Fluid Dynamics (CFD), Microfluidics, Particle Tracing for Fluid Flow Version 6.0 0 Replies
I am relatively new to comsol and have been attempting to fill a large microfluidic well. The simulation is in 2D, with a rectangular channel of length 1 mm and width 0.1 mm feeding into a well of radius 2.3 mm, where an outlet channel is then connected to the end of the well (same dimensions as the inlet channel. I have been able to successfully simulate this structure on a smaller radius well, but have been experiencing a lot of trouble in terms of getting viable results for the larger radius well. The most success I usually have is with a mapped mesh. I am unable to attach the file at the moment, but will do so in the coming hours. If anyone has any experience doing such a simulation, your insight would be extremely helpful, thank you!
Hello Wallie Z
