Integrating semiconductor and magnetic fields module
I want to analyze the impact of magnetic field on a Si block (1x1x1 um) with doping density variation subject. The questions are as follows: 1. What would be the simplest way to integrate the semiconductor module with the magnetic fields module to achieve the above? 2. Is there a way to specify the doping distribution without using the semiconductor module, eg just in the material definition of Si, so as to avoid the semiconductor module entirely? Would this make the analysis less precise?
0 Replies Last Post 27 févr. 2025, 14:23 UTC+1
Hello Munazza Sayed
Reply
