Two sided Wall (line) boundary conditions - Form Assembly
Hello, when there is a line which is wall in form assembly, so, there is 2 sides of this wall. Can I use different boundary conditions in this situation? As example: one side is No Slip and the other Slip condition?
I make a simple test and When I did this, It was give different velocities when I compare the side of Slip condition. So, when I use the 2 sides as Slip it give me correct solution. When I use No slip in one side and Slip in another, the Slip condition is giving different value compared the prior test.
0 Replies Last Post 4 juil. 2025, 11:04 UTC−4
Hello Pedro Antonio Chaves
