parametric sweep in a contact problem
Posted 10 avr. 2013, 19:49 UTC+2 Studies & Solvers, Structural Mechanics Version 4.3a 3 Replies
The attached file shows a simple axisymmetric problem in 4.3a where a screw-shaped part is being pushed into some uniform bone by an axial force.
In the attached model, there are identity pairs between the screw and bone, and the model runs fine with a parametric sweep involving an increasing force on the screw. However, my question is this: Is there any reason this problem would not work properly when I have contact pairs replacing the identity pairs in this same geometry? I cannot get that contact version to run in a parametric sweep mode although it runs fine as a single contact problem. When I try a sweep, the error reads "error in multiphysics compilation". (While the contact problem runs OK without the parametric sweep, I am curious whether I can use the parametric sweep mode in a contact problem.)
Second question: In one of Ivar's notes to a user asking about parametric sweeps, he wrote the note below, see 3rd paragraph. That makes me double-check one point: Does 4.3a by default use a "continuation mode" type of sweep? My model attached did seem to run this way based on the results, but I did not see any place in the solver node where I could select a "continuation" sweep vs. the other type of sweep. (I'm fine with a continuation sweep, but I was just wondering.)
October 18, 2012 11:09am UTC in response to kishore naik
Re: parametric sweep
add the parameters in the Parameter list, replace the circle centre position by these parameters, call up a specific Parametric node in the solver sequence, add in all relevant parameters, and adjusts ways to combine them. and off you go
Note: when changing the geometry, try to avoid changing topology, as this renumbers the entities (domain, boundary edge, points IDs) and often COMSOL get confused (note this is getting less and less true, as COMSOL's algorithms seem to drastic improve with the latest versions, and it's working even better if you use systematically the Definitions Entity Selections nodes)
Another point in v4.3a, there is a new feature, COMSOL checks if the parametric sweep needs to be "outside" the solver sequence or can be included into the solver as a continuation mode (automatic), sometimes now you need to turn this feature "off" to impose an external (looping around the full model, not only the solver sequence) parametric sweep. Check the latest doc
3 Replies Last Post 11 avr. 2013, 14:16 UTC+2
