COMSOL 5.6 – Discrepancy between simulated and measured loudspeaker electrical impedance
Hi, I am modeling a loudspeaker coupled to a transmission line partially lined with porous material (Visaton fiber), using COMSOL Multiphysics 5.6 and the Pressure Acoustics interface. The loudspeaker is represented by a lumped electromechanical model using experimentally determined Thiele–Small-Leach parameters. The attached plots compare the simulated and measured electrical impedance, both magnitude and phase. The agreement is generally good, but there is a significant discrepancy around the first resonance (approximately 45 Hz), both in peak amplitude and phase. The second resonance, near 100 Hz, is reproduced more accurately. The free-air electrical impedance of the loudspeaker has been independently verified, so the discrepancy appears to be associated with the acoustic loading of the transmission line. Could this behavior be related to the modeling of the porous lining, the acoustic boundary conditions, or the coupling between the loudspeaker and the acoustic domain? I would appreciate any suggestions on which physical assumptions or modeling settings should be checked. Many thanks
1 Reply Last Post 24 nov. 2026, 03:13 UTC−5
Posted: 17 minutes ago 24 nov. 2026, 03:13 UTC−5
Looks like some damping is off, but not sure which curve relates to what. So yes, perhaps some porous lining issue.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Reply
