a problem with boolean operation Difference
Posted 11 nov. 2013, 02:41 UTC−5 Geometry Version 4.3b 4 Replies
Hello!
I'm trying to create a cylindrical hole in a cube. So I built a cube by extrusion from a plane and a cylinder inside this cube by extrusion from a plane. Length of the cylinder is equal to the side of the cube. So when I apply boolean operation Difference, I expect that the cylinder will be subtracted from the cube and I will see a cylindrical opening in the cube. Instead I see that a thin wall (surface) is left on one side of the cube. How do i get rid of this spurious surface?
4 Replies Last Post 11 nov. 2013, 10:42 UTC−5
