Prescribe Displacement
Hi everybody,
I currently used Comsol to see the force_displacement relation of a bistable nonlinear-cantilever beam,
If I sweeping by varying the Force and then caculated Total Displacement, I cannot get the unstable solution.
I thinks that I should sweep the Displacement and then calculated again the Force. It will be better.
So, I set "Precribed Displacement" as I desired, and "include nonlinear geometry" and calculated the "Reaction Force", however, I am not get correct results ( compared with Force sweep),
And also, if I set "Precribed Displacement" in boundary or in edges, it give me different results,.
Hope that you have some experiement about this to help me ?
0 Replies Last Post 27 janv. 2014, 10:44 UTC+1
Hello Cuong Nguyen
