Simple optimization
Posted 7 mai 2014, 07:44 UTC−4 Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3b 0 Replies
Please give a hand.
There is a simple problem of optimization. Knowing the experimental value of the function (for example, the maximum temperature of the body at a specific point),I need to find the coefficient of thermal conductivity which makes calculated body temperature max close to the experimental one.
I understand that this is a simple task, but I cannot solve it in Comsol. I need to choose an "Optimization" section in the "Study" partition or I need to add the "Optimization" partition from physics list? If option 2, then what subdivisions should be set in the module?
Lessons from the user Guide are useless here, these examples I have already studied and they have not solved my problem
Thank you.
Hello Mikhail Polous
