Optimization problem
Hi everybody!
Please give a hand.
Knowing the experimental value of the function (for example, the maximum temperature of the body at a specific point), I need to find the optimal value of parameter (for example, coefficient of thermal conductivity) at which calculated body temperature should be as close to experimental. This parameter can be in a certain range of values. How can I solve this task in Comsol?
Thank you.
0 Replies Last Post 10 mai 2014, 15:35 UTC+2
Hello Mikhail Polous
