manipulate initial value in S.manager
Posted 27 sept. 2010, 09:50 UTC−4 1 Reply
as well know my problem is Stationnary nonlinear multiphysics of 3 application , and I want to simulate it in two steps:
in the first step, I estimate the initial value With low relative tolerance (1e-3), in which case I should mention in The solver manager option from the initial value expression, then i click solve.
after the end of the first stage, back to back on default tolerance (1e-6), and mention another option current solution In The solver manager, then i click Restart hence my question:
how to define the results of the first step as initial value for the 2nd step in solver manager?????
thank you very much
thank you very much
1 Reply Last Post 27 sept. 2010, 10:42 UTC−4
