Selecting geometary objecs inside another object
Posted 14 oct. 2010, 13:04 UTC−4 7 Replies
For v4 RF, if a boundary of an object inside another object is to be selected, the one way that I know is from selection list. Is there any possibility to select it with graphical interface, by mouse click.
Irfan
ave you tried to click several tims, normally you cycle through the objects "hit" by the projection view. Sometimes transparent or wireframe is showing it up better
Thanks Ivar, I tried multiple times hit, it worked.
Irfan
In addition to what you tried, it can help to hide objects that are in front of it. The hide-buttons are located above the graphics window.
What's more, once you have selected those "buried" surfaces, it can be helpful to save the selection. To do this, go to "Definitions" and then "Add selection". Alternatively, when you have selected them under a boundary condition, there is a small button that will automatically save the current selection. Be sure to give it an appropriate name though!
Good luck,
Ruud Borger,
Comsol
It is really wonderful and what I am looking for.
Irfan
do not forget that you can have several views (under definitions and under Results (postprocessing) with different "hide" levels (only for views under Definitions)
www.comsol.com/support/knowledgebase/1168/
