Export data into a file
Hi all,
I am trying to export the data (1D line graph) to a txt file from comsol 4.1. In the txt file created by comsol 4.1, the data were saved along the same row, e.g., x1 y1 x2 y2 ....
In comsol 3.5, the x and y data are saved into two columns, e.g.
x1 y1
x2 y2
The old format (3.5) is a lot easier to read. Is there any way to do the same in 4.1?
Also, I saw some discussions on "transfering" the data in a table and exporting the data from table. But I did not figure out how to do this. Will the data be saved into two columns in this way?
Thanks a lot!
Hainan
2 Replies Last Post 5 juin 2011, 22:26 UTC−4
Hello Hainan Wang
Posted: 1 decade ago 4 juin 2011, 08:33 UTC−4
I am trying to export a plot to a txt file in Comsol 4.1a, but I couldnt figure out how. Is there a tab or an icon?
Posted: 1 decade ago 5 juin 2011, 22:26 UTC−4
Hi all,
x1 y1
x2 y2
Thanks a lot!
Hainan
You can open the txt file using the Excel, then the contents will be much easier to read.
[QUOTE] Hi all, I am trying to export the data (1D line graph) to a txt file from comsol 4.1. In the txt file created by comsol 4.1, the data were saved along the same row, e.g., x1 y1 x2 y2 .... In comsol 3.5, the x and y data are saved into two columns, e.g. x1 y1 x2 y2 ... The old format (3.5) is a lot easier to read. Is there any way to do the same in 4.1? Also, I saw some discussions on "transfering" the data in a table and exporting the data from table. But I did not figure out how to do this. Will the data be saved into two columns in this way? Thanks a lot! Hainan [/QUOTE] You can open the txt file using the Excel, then the contents will be much easier to read.
